Revit is misbehaving - or maybe I am...schedules and design option set fun
erinznire
erinznire
I've been Googling for days and I cannot figure out what is wrong with my file for it not to be doing as instructed...According to: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN... - "You can dedicate all kinds of views (including schedules) to a specified design option. For example, you can create one schedule for the primary option and another schedule for a secondary option. Each schedule lists elements that are in the main model as well as elements that are in the specified design option."
What if this isn't working - My schedule doesn't seem to be taking out the other design options, they are all listed together...?? below is a shot of the options I have for visibility - the others are Automatic, and have no "none" option like I would have expected - is it because they are all in different design sets and if so how can I work with that? I can barely remember now why I needed sets instead of just options, I think it had something to do with the fact that each bay will have different options and I needed to separate each bay as well as the options for that bay. Can I make a parameter that identifies the design option set it's in, if so how?
Can you add an "Empty" option for each option set and put nothing in it so that you can set your schedule to "empty" for sets that you don't want to include?
erinznire
I love you, so simple I should have been able to come up with that! Amaze balls!
