Hi there! I have a big problem with revit 2018.2. When I make changes in 3d, like changing a window's sill height, roof height, etc, is always thinking around 30-60 seconds, and the loading cursor from windows is apearing, and when I click on the display it say not responding, but if I wait is coming back with the change I made. Is very frustrating couse I have a very powerful pc: i7 8700k, gtx 1070, ssd, 16gm ram, and I can't understand why is doing that! When I had i3 with gtx 960 everything was ok! Can you please help me! Thanks!
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
you are working in a Realistic view.. Revit will take a lot of time to update the view .. work in hidden or shaded...
Thanks for the answer, but it has nothing to do with that! One of my friends has gtx 1060 and he has not even a small problem with that, and he work as me just with realistic mode. I cant see the drop menus too, I click on them to change from a level to other, or the wall settings ((centerline, finish face, exterior face, etc) and it won't drop down. :(( I think there is an incompatibility with the GPU... I don't know. I change everything, CPU, memory ram, ssd, motherboard and nothing. I had to test the Graphic card on another pc and see if is working there.
Hi @Anonymous
Let me know if the recommendations in the above article help and improve Revit's performance.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
I tried that, but nothing changes! I have i7 8700k and 16 gb of memory with GTX 1070, it should be more than enought for revit. I don;t know what happens here is very strange, couse on a lower perfprmance PC it's runing as hell. Thanks anyway!
Hi @Anonymous
Thanks for getting back.
Sorry to hear that the issue still persists. Can you send us your recent journal and NFO?
Let me know if you want a private upload folder and if you have questions on finding these files.
Viveka CD
Hello! I attached those files in this reply, and a photo when I tryed to zoom out and what happends after that with task manager on, to see that the GPU is not used. I hoppe that you'll find a solution. Thanks again!
Hi @Anonymous
Great! Thanks for sharing these files.
I will update with further developments in terms of finding a solution.
We will try it on our side, see if we get the same behavior, and I will let you know.
Regards.
Viveka CD
Hi @Anonymous
Sharing an update: your issue in in progress and I'll update with further developments.![]()
We also require a system NFO file for further diagnosis. Let me know if you have questions on the same.
Viveka CD
Hi there! In the sys.rar is the .nfo file, couse the system denied my uplod for .nfo files.
@Anonymous I will send you a private upload folder, please expect a link shortly. I will send to your email on file.
Viveka CD
@Anonymous Upload folder sent! ![]()
Let me know if you have trouble accessing this folder, and let me know when you are done uploading.
Viveka CD
Done! Journal, a printscreen when I tried to zoom out and the system file. Thanks!
Hi @Anonymous
Great. Thanks for the update!
Viveka CD
Hi @Anonymous
Please update your Revit to the latest build and see if this helps resolve your issue.
Your journal shows that you've not installed current updates.
Viveka CD
