I am attempting to draw a sidewalk to a main access ramp on a project, but revit keeps giving me the same Intersecting Lines message. I have tried a few different sketch configurations, but no dice. Ideally, the sidewalk wouldn't wrap around the ramp, but rather slightly blend into the shape, as it is represented below.
In edit mode in Revit you have to avoid intersections like below.
The linework must be a closed shape without gaps or intersections. The end of a line must be the start of the second.
Try to do two different objects.
If my post help you, please give a like.
If your question was answered please mark it with ACCEPT SOLUTION. This helps others to find answers...
Kostas Kouris
Architect Engineer, M.Sc., ACI, ACP
