Revit into Autocad very slow
Every time I am importing and opening a Revit file into Autocad, Autocad gets super slow. Is there any setting that I can fix to get especially the 3dviews running smoothly?
Thanks for the tip.
CADmonkey_UK_Building_Services
To use an old quote - maybe you need to sharpen your pencil. Maybe export one Floor at a time instead of the whole building.
How big are your RVT & DWG files? Acad can't deal with large files like Revit can.
You could try globally turning off Hatch display in Acad, which might help a bit. The setvar is FILLMODE (set this to 0)
Please select the Accept as Solution button if my post solved your issue.
Intel 7740x - Quadro 6000 - 32Gb RAM - CADmouse - Logitech G710
aRcHiTeCt.JM
… hi @Anonymous
… clean your model / layers a little bit
… follow this link revit to autocad
… very clear on how to edit or delete unnecessary REVIT “stuff”
… so … the model will get kind of light
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
