My interface, does not show some commands! For instance, the command copy, does not show the check box showing multiples, the command off set does not show as the original interface the numbers to do the offset.
Someone could help me on that matter.
Appreciatte
George
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Gelöst von jorgedacunha60. Gehe zur Lösung
Revit only has 2 locations for this to be, top of the screen under the panels or bottom above the state/worksets. It is easy to move by right clicking, but the only options are top or bottom. It should also show up with a slight green tint any time you select an object.
Sounds like you have no Options Bar. Is that correct?
So, if you don't get an Options Bar when a command is invoked. such as Walls or Roof or Floor; then do a Repair installation of Revit.
How to reinstall or repair your Autodesk product | Search | Autodesk Knowledge Network
