i new with Revit software, i hide properties pallet by mistake because when i click on it it don't open Type properties pallet, why?
Gelöst! Gehe zur Lösung
Gelöst von Mohamed-Nassar. Gehe zur Lösung
Gelöst von lucdoucet_msdl. Gehe zur Lösung
Gelöst von mauricio_mssf. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Gelöst von constantin.stroescu. Gehe zur Lösung
go to View > User Interface>click on the small triangle from bottom right to open menu and check Properties
Constantin Stroescu
You can also select on any element and activate Properties from the Right-Click Menu.
Hi @Anonymous
Is Just type de Shortcut key PP.
If the answer solves your problem, click Accept as Solution this helps other users to quickly find an answer and let a like if you liked it.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
Mauricio Santos Filho Arquiteto | BIM Manager
The combination CTRL key + 1 will also open/close the object properties window.
-luc
Hello, Check if you have double screen it doesn't open there, so for it hide go to View then Window panel > User interface select Properties.
Hi, I have checked the properties box in the user interface but it still doesn't appear on my page. Any ideas??
