revit insulation batting lines width dialogue box
8 ANTWORTEN 8
Nachricht 1 von 9
979 Aufrufe, 8 Antworten
revit insulation batting line width dialogue box does not register Esc/ Enter keystrokes/ keyboard command. This is a bug that should be fixed. When the insulating batting lines width is adjusted, the mouse cursor becomes stuck inside of the Width dialogue box, and can only be 'freed' by clicking outside of the dialogue box, after fixing the numerous (Esc/Enter) keystrokes being logged.
8 ANTWORTEN 8
Nachricht 2 von 9
Avaris.
als Antwort auf: Anonymous
Nachricht 3 von 9
als Antwort auf: Avaris.
2018.3
Nachricht 4 von 9
Mine works.
Nachricht 5 von 9
Corsten.Au
Hello
Am sure its about updating the Revit..am using build "18.0.0.420" and works fine..
attaching a screen-cast as well..
https://autode.sk/2ztTNVF
cheers!
Corsten
Building Designer
Nachricht 6 von 9
als Antwort auf: Corsten.Au
Hello: Would not the Revit 2018.3 be later, and more current version than
"18.0.0.420"
Nachricht 7 von 9
als Antwort auf: barthbradley
It's not that it does not work. It's that the only way to get your cursor out of the dialogue box is to click outside of it. That is mouse dependent, and not in the spirit of DOS keyboard commands. Hitting Esc or Enter does nothing. This is the point. These two keystrokes should always work, during the insulation batting lines width adjustment, when the insulation batting lines width adjustment dialogue box is selected.
Once inside on the insulation batting line width dialogue box, the keystrokes Esc, and Enter are not functional. This is a bug that should be fixed. When the insulating batting lines width is adjusted, the keyboard is used to enter the dimension of the insulating line, to be followed by a keystroke Enter to complete the command. At a minimum, hitting Esc should exit out of the dialogue box. Why limit to mouse cursor clicking?
Nachricht 8 von 9
What version are you on? I cannot replicate the behavior in 2018.
Nachricht 9 von 9
I am in 2018.3.1
