I tried to install Revit 2021 student version but it didn't work. A message says the installation could not proceed because "Revit.exe" is still running, but there is no program running. I thought it might happen due to an older version installed in my computer (2016), but when I tried too uninstall it, the uninstaller send the same message.
I would look for any Revit and Autodesk process in task manager and stop them. I would also exit the Autodesk Desktop App if it's running. If that doesn't work, restarting your pc and attempting to uninstall right away should help.
There's no autodesk ou revit process running according to the task manager. I tried to restart the pc also, but but it didn't fix anything either
