Revit Installation
3 ANTWORTEN 3
Nachricht 1 von 4
SMARTIN2Y5PAD
439 Aufrufe, 3 Antworten
Revit Installation
I want to download the revit 2021/2022 installer with the "Browser Download installation" (.sfx files). According to some videos and blogs I just have to select the "Browser Download" option but I can't see it. The reason behind this option is to have access to revit 21 & 22 versions if they are removed from the download center.
Beschriftungen (2)
3 ANTWORTEN 3
Nachricht 2 von 4
juliar123
als Antwort auf: SMARTIN2Y5PAD
Are you doing this through your Autodesk account through a web browser or the Autodesk Desktop App/Autodesk Access? Go to your Autodesk account, it's much easier to download and create deployments.
Nachricht 3 von 4
SMARTIN2Y5PAD
als Antwort auf: juliar123
Yes, I am using the Autodesk manage website (https://manage.autodesk.com/). With the deployment I can create de .sfx files?
Nachricht 4 von 4
juliar123
This gives you a how to do the deployment as well as what the outputs are: https://www.autodesk.com/support/download-install/admins/create-deployments/create-deployments-from-...
If you are not looking to create a deployment, you can also download software from the All Products and Services tab on the left of the screen.
