Ive tried all methods showed in this forum.
clean all C++ file and reinstall win 10. It just didn't work out.
here is the error log:
2017/3/16:10:49:29 mark DREAMER === Setup started on DREAMER by mark ===
2017/3/16:10:49:29 mark DREAMER Path_Length: 155
2017/3/16:10:49:29 mark DREAMER Current Directory C:\Users\mark\AppData\Local\Temp\_AI531A.tmp
2017/3/16:10:49:29 mark DREAMER Launch
2017/3/16:10:49:29 mark DREAMER Download Skipped SETUPMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/RVT/WI/{A63D28CA-80F2-4F15-95F0-F604AD390EA8}/SETUP...
2017/3/16:10:49:29 mark DREAMER Download Skipped SETUP_CONFIG http://efulfillment.autodesk.com/NET16SWDLD/2016/RVT/WI/{A63D28CA-80F2-4F15-95F0-F604AD390EA8}/SETUP...
2017/3/16:10:49:29 mark DREAMER Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\mark\AppData\Local\Temp\_AI531A.tmp\Setup\RevitSetup.dll
2017/3/16:10:49:29 mark DREAMER Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/3/16:10:49:30 mark DREAMER PageOpen LaunchDialog
2017/3/16:10:49:32 mark DREAMER Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\mark\AppData\Local\Temp\_AI531A.tmp\Setup\RevitSetup.dll
2017/3/16:10:49:32 mark DREAMER Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2016. URLTitle= URLLink=
2017/3/16:10:49:32 mark DREAMER PageOpen LicenseDialog
2017/3/16:10:49:36 mark DREAMER PageOpen ProductInfoDialog
2017/3/16:10:58:14 mark DREAMER PageOpen ProductSelectionDialog2
2017/3/16:10:58:50 mark DREAMER PageOpen FullProgressDialog
2017/3/16:10:58:50 mark DREAMER Download Skipped STARTMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/RVT/WI/{A63D28CA-80F2-4F15-95F0-F604AD390EA8}/START...
2017/3/16:10:58:50 mark DREAMER Download Skipped VCREDIST2005X86 http://efulfillment.autodesk.com/NET16SWDLD/2016/RVT/WI/{A63D28CA-80F2-4F15-95F0-F604AD390EA8}/VCRED...
2017/3/16:10:58:50 mark DREAMER Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2016\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\mark\AppData\Local\Temp\vcredist_x86_2005.log"" "
2017/3/16:10:58:54 mark DREAMER Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2017/3/16:10:58:54 mark DREAMER Download Skipped KB958314ATLX86 http://efulfillment.autodesk.com/NET16SWDLD/2016/RVT/WI/{A63D28CA-80F2-4F15-95F0-F604AD390EA8}/KB958...
2017/3/16:10:58:54 mark DREAMER Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2016" SETUP_PACKAGECODE={7346B4A0-1600-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/16:10:58:54 mark DREAMER Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2017/3/16:10:58:55 mark DREAMER Download Skipped KB958314MFCX86 http://efulfillment.autodesk.com/NET16SWDLD/2016/RVT/WI/{A63D28CA-80F2-4F15-95F0-F604AD390EA8}/KB958...
2017/3/16:10:58:55 mark DREAMER Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2016" SETUP_PACKAGECODE={7346B4A0-1600-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/16:10:58:56 mark DREAMER Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2017/3/16:10:58:56 mark DREAMER Download Skipped KB958314CRTX86 http://efulfillment.autodesk.com/NET16SWDLD/2016/RVT/WI/{A63D28CA-80F2-4F15-95F0-F604AD390EA8}/KB958...
2017/3/16:10:58:56 mark DREAMER Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2016" SETUP_PACKAGECODE={7346B4A0-1600-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/16:10:58:57 mark DREAMER Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2017/3/16:10:58:57 mark DREAMER Download Skipped KB958314OPENMPX86 http://efulfillment.autodesk.com/NET16SWDLD/2016/RVT/WI/{A63D28CA-80F2-4F15-95F0-F604AD390EA8}/KB958...
2017/3/16:10:58:57 mark DREAMER Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2016" SETUP_PACKAGECODE={7346B4A0-1600-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/16:10:58:58 mark DREAMER Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2017/3/16:10:58:58 mark DREAMER Download Skipped KB958314ATLX64 http://efulfillment.autodesk.com/NET16SWDLD/2016/RVT/WI/{A63D28CA-80F2-4F15-95F0-F604AD390EA8}/KB958...
2017/3/16:10:58:58 mark DREAMER Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2016" SETUP_PACKAGECODE={7346B4A0-1600-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/16:10:58:59 mark DREAMER Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2017/3/16:10:58:59 mark DREAMER Download Skipped KB958314MFCX64 http://efulfillment.autodesk.com/NET16SWDLD/2016/RVT/WI/{A63D28CA-80F2-4F15-95F0-F604AD390EA8}/KB958...
2017/3/16:10:58:59 mark DREAMER Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2016" SETUP_PACKAGECODE={7346B4A0-1600-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/16:10:59:00 mark DREAMER Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2017/3/16:10:59:00 mark DREAMER Download Skipped KB958314CRTX64 http://efulfillment.autodesk.com/NET16SWDLD/2016/RVT/WI/{A63D28CA-80F2-4F15-95F0-F604AD390EA8}/KB958...
2017/3/16:10:59:00 mark DREAMER Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2016" SETUP_PACKAGECODE={7346B4A0-1600-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/16:10:59:01 mark DREAMER Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2017/3/16:10:59:01 mark DREAMER Download Skipped KB958314OPENMPX64 http://efulfillment.autodesk.com/NET16SWDLD/2016/RVT/WI/{A63D28CA-80F2-4F15-95F0-F604AD390EA8}/KB958...
2017/3/16:10:59:01 mark DREAMER Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2016" SETUP_PACKAGECODE={7346B4A0-1600-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/16:10:59:02 mark DREAMER Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2017/3/16:10:59:02 mark DREAMER Download Skipped VCREDIST2005SP1ATLX64 http://efulfillment.autodesk.com/NET16SWDLD/2016/RVT/WI/{A63D28CA-80F2-4F15-95F0-F604AD390EA8}/VCRED...
2017/3/16:10:59:02 mark DREAMER Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Revit 2016\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\mark\AppData\Local\Temp\vcredist_x64_2005.log"" "
2017/3/16:10:59:06 mark DREAMER Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2017/3/16:10:59:06 mark DREAMER Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2017/3/16:10:59:07 mark DREAMER Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2017/3/16:10:59:07 mark DREAMER Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2017/3/16:10:59:08 mark DREAMER Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2017/3/16:10:59:09 mark DREAMER Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2017/3/16:10:59:09 mark DREAMER Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2017/3/16:10:59:10 mark DREAMER Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2017/3/16:10:59:10 mark DREAMER Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2017/3/16:10:59:10 mark DREAMER Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
here is the material library log:
2017/3/16:10:49:29 mark DREAMER Current Directory C:\Autodesk\Autodesk_Revit_2016_English_Win_64bit_wi_en-US
2017/3/16:10:49:29 mark DREAMER CommandLine /URL "http://efulfillment.autodesk.com/NET16SWDLD/2016/RVT/WI/Autodesk_Revit_2016_English_Win_64bit_wi_en-..." /akamai
2017/3/16:10:49:30 mark DREAMER === Setup ended ===
Gelöst! Gehe zur Lösung
I'm not sure what the other methods from this forum are that you have tried, but my first step with install issues when it gets to C++ is to uninstall all versions of the issue C++, so in this case all the Visual C++ 2005 Redistributable. Do this through the Windows control panel, reboot, then try the Revit install again.
Sorry if you've already tried this one.
I literally solved on my own.
OKAY let me explain.
If you see error 1619 and 1603, first step clean C++ and reinstall again.
If 1619 continues, because the C++ wont install. the problem is that your .NET FRAMEWORK File is damaged.
please refer this link:
Run the framework repair tool. https://www.microsoft.com/en-us/download/details.aspx?id=30135
follows the step. don't exist too quickly. see the instruction carefully.
At the end, I managed to install the revit 2016.
good luck out there.
All the best
mark
