Hi All,
I have tried to read the attached ifc file into revit architecture 2016. The exporter application fills the type name information at IfcCOlumnType:
#74=IFCCOLUMNTYPE('0B4oDrLj95uPG6aq_wkUC4',#5,'SET - RECT. 30x30',$,$,$,$,$,$,.NOTDEFINED.);
Which refers to this column:
#72=IFCCOLUMN('2KBELrLj95uPG6aq_wkUC4',#5,'Column 1',$,$,#71,#48,$);
My problem is, that 'SET - RECT. 30x30' is not readable anywhere in revit.
But!
When the exporter fills the type name into IfcColumn at parameter 5 (ObjectType), it will be ok in revit.
I think this is not the correct procedure. Do you know anything, if it will be corrected or not?
Strange, but the same thing doesn't apply to IfcWallStandardCase - IfcWallType. In that case, the type name is read from the TypeObject correctly.
Thanks in advance,
Attila Balazs
Gelöst! Gehe zur Lösung
Gelöst von ryan. Gehe zur Lösung
You might want to ask your question here: https://sourceforge.net/p/ifcexporter/discussion/general/
It's a more IFC/Revit specific forum.
