Revit IFC Export object type and name properties override
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
juhana.kolppo
6280 Aufrufe, 6 Antworten
Hello
How can i override object type and type name parameters when exporting model form revit to IFC.
Type name parameter is always like; family name:type name. Is there some shared parameter value to override this.
6 ANTWORTEN 6
Nachricht 2 von 7
alan_eu
als Antwort auf: juhana.kolppo
Just curious... Why do you need to change this structure? :leicht_lächelndes_Gesicht:
It's something that you couldn´t change on Revit, but you could edit your IFC file on notepad and edit it manually. Do I recommend to do this. Maybe not :grinsendes_Gesicht_mit_lächelnden_Augen:
Alan Araújo EESignature
Bee1ColabInstagram Alan Araújo RevitBee1ColabGrupo Whatsapp
Usuários do Autodesk Community:
  • Se a resposta resolveu o seu problema, clique em Aceitar como Solução! isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou :leicht_lächelndes_Gesicht:
  • Manda um alô nas minhas redes sociais com +600 vídeos de de Revit/BIM, Templates e conteúdos semanais! Gratuitos! :leicht_lächelndes_Gesicht:
Nachricht 3 von 7
TripleM-Dev.net
Object type can be overwritten by adding the parameter to elements (type or instance) IfcExportAs
for example a Generic Model can be exported as a Window (Value = IfcWindow)
Note: this doesn't work for all types!
Name/TypeNames can be overwritten by:
Adding a instance parameter named: IfcType (only needed for user families!)
Adding a instance parameter named: IfcName
Adding a type parameter named: NameOverride (only needed for system families, like walls)
As stated above there is some difference between UserFamilies and system families.
Also see: https://sourceforge.net/projects/ifcexporter/  for some more detailled info
Below a sample of the Ifc override result (Left has the override for a wall, right the original)
Sample With Ifc overrides and withoutSample With Ifc overrides and without
- Michel
Nachricht 4 von 7
cba
als Antwort auf: TripleM-Dev.net
I am experimenting and i am trying to follow your steps but fail to get same results.
Adding a type parameter called NameOverride for system families like walls does not seem to override Name, but rather Type Name. .
Same applies for IfcName for non-system families like furniture.
Not quite the same outcome, but close i guess.
Name is still just displaying: "Basic Wall:Wall 1:7444"
Type name: "NameOverride Test"
But if i go into [Relations/defines by type] in solibri and expand suddenly i am able to find identity data with Name: "NameOverride Test"
Any hints?
Revit 2020 (20.2.30.42)
Nachricht 5 von 7
cba
als Antwort auf: cba
Edit: Sorry for the confusion - I figured it out.
Instance parameters goes to Name
Type parameter goes to Type Name.
(As you wrote - woops)
Logical when you think about it. However i was hoping i could dictate Name in IFC by using type parameters in Revit as it is being picked up as default value in other IFC software platforms.
I guess it is not possible :enttäuschtes_Gesicht:
Nachricht 6 von 7
miguel.gutierrezD74CZ
Sorry to bring this up, but I'm struggling to override the IfcName parameter:
The txt file Im using as shared parameter is from this website:
https://github.com/Autodesk/revit-ifc/blob/master/Install/Program%20Files%20to%20Install/IFC%20Share...
However, I dont see any change on IfcName parameter value. This is done in revit 2023. Is there any step I'm missing?
Thanks in advance
Nachricht 7 von 7
RvdScheur
In addition, Object Type (instance level) and Element Type can also be overwritten on Type level:
Make sure you add IfcObjectType[Type]  as shared parameter due to the [] in the name.
