Revit: How to change the crop boundary line thickness
protikkayal
Message 1 of 9
protikkayal
Is there any way to increase "Crop boundary" line thickness?
@protikkayal,
zsolt.varga has edited your subject line for clarity and search engine optimization.
Original: "Crop boundary line thickness"
Replies (8)
Message 2 of 9
piotr.bocian
Sure. Just go to Manage - Additional Settings - Line Styles and edit <Sketch> lines thickness.
Message 3 of 9
The crop boundary?  It's not controlled by Line Style or Object Style.
...you can change the Line Weight of the Sheet Viewport though.
Message 4 of 9
Corsten.Au
Hi..
You can either choose to hide that line or print it black..I would be surprise if someone comes
up with revit settings to change its colour.. quite a good question...
Please upload a reference image if someone comes up with solution..
( mention Revit Version as well )
Hide Crop BoundariesHide Crop Boundaries
Corsten
Building Designer
Message 5 of 9
piotr.bocian
Sorry, it is not answer to this post. I did it by mistake.
Message 6 of 9
No biggie.  It happens.  Thanks for contributing.
Message 7 of 9
protikkayal
I found that inside the Section or Elevation views it is possible to change the crop boundary line thickness, color, line pattern by "Override Graphics in View>By Element" but it is impossible in plan views. But this being a quite lengthy for many views....... so if there any other process to control it and for "Plan views crop region" also, then it will help me a lot.
Thanks to all.
Message 9 of 9
Go to manage/object styles/walls (change the cut line of the wall to a smaller line weight so it will change the outer wall boundary ) then click on the plus (+) beside the wall and increase the line weight of the common edge thus increasing the inner boundary of the wall
