Revit : How to add a curtain wall type
I've recently begun to use Revit. And require some help with it.
This question is mostly related to the video lesson from the "Autodesk Education" channel I saw on YouTube. When I tried to choose a curtain wall type, I only had 3 of them at my disposal : Curtain Wall, Extirior Glazing and Storefront. And that is without two more (Curtain Wall - Standard and Storefront - MPK), enable in the video. Could you tell me, how can I add those two to my list of curtain walls
L.Maas
The three you mentioned are the ones standard with Revit. Can be that the other two were already made (by the user) or that they were part of of a different template.
However you do not require those. The curtain walls definitions can be duplicated, renamed and modified to your liking. The three main ones are just good starting points for your own curtain wall definitions.
Louis
Please mention Revit version, especially when uploading Revit files.
I see! Thank you!!!
