Greetings,
Like I want to Load the family into Revit, but in only one "View", I don't want it to appear in every view/sheet?
Otherwise, I'm loading Family and need to sort every page and "Hidde" it.
Gelöst! Gehe zur Lösung
Gelöst von rxi.gg. Gehe zur Lösung
You can not do that. A loaded family will be seen by default in all viewports. What occurs to me is that you create a Workset for these families and only show it in the viewports that interest you.
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Hi, @cadedu22, by its own nature, all model families -as any model element- are visible in all views, depending on V/G settings. Only annotation elements and families -like Detail items, as @ToanDN said- are visible in the specific view were created or placed.
Thank you for answers, in this case, "Workset" solution works.
