Revit Graphics - Edit Type & Workset Name Text Size
17 ANTWORTEN 17
Nachricht 1 von 18
Kev_D
718 Aufrufe, 17 Antworten
I am wondering why some of the text size goes much larger:
  • Type Selection
  • Edit Type
  • Workset Name
I tried disabling Hardware Acceleration but it did not fix it.
When I close Revit and open it again, it is back to normal, but when I start working, the letters go back to being larger.
I have my laptop connected to 2 screens. It happens on both screens.
17 ANTWORTEN 17
Nachricht 2 von 18
als Antwort auf: Kev_D
Fascinating.
Following...
....maybe a Windows Accessibility Feature turned on?
Nachricht 3 von 18
Check Windows Display Scaling, and match vertical resolution for both screens.
Nachricht 4 von 18
Kev_D
I played around with some of those settings already and it has not fixed it. Like I said, when Revit opens it is ok, then when I open a 3D view, the letters get bigger. The same also applies to the Material Browser
Nachricht 5 von 18
d.ahmed.LW
Are you using multiple monitors by any chance?
Nachricht 6 von 18
Kev_D
als Antwort auf: d.ahmed.LW
Yes, I am using 2 monitors. 1 of them mirrors the laptop screen, and the other is number 2. Sometimes I close the laptop lid, and sometimes it is open, but the problem persists.
The 2 monitors are different in size slightly. one is 20in (1) and the other is 22(2). The laptop is a 14in display.
Nachricht 7 von 18
Sized of monitors don't matter, but their resolutions and display scaling do.
Nachricht 8 von 18
Kev_D
als Antwort auf: ToanDN
yeah didn't think it did matter, but all settings are the same. no issue with any other apps.
Nachricht 9 von 18
And what are they?
Nachricht 10 von 18
Kev_D
Basic apps such as Office, Adobe, CAD also. Nothing as powerful as Revit. . No issue when viewing documents, images, videos, web pages. Only those specific parts of Revit like mentioned above.
Nachricht 11 von 18
I am asking about the settings, not other apps. Other apps behaviors have no bearing on Revit's.
Nachricht 12 von 18
d.ahmed.LW
No I mean what are your settings? The number of monitors, size and other apps have no connection with Revit. I think the display resolution and other settings is where we need to look into.
Nachricht 13 von 18
Kev_D
My bad. I seen "and what are they" and the last thing I mentioned is Apps, instead of looking at your highlighted section.
Assumption is the mother of all f**kups :strahlendes_Gesicht_mit_lächelnden_Augen:
Nachricht 14 von 18
Kev_D
Both Monitors are 1980x1080.
The laptop display is
The laptop lid is closed, and mirrors to screen 1, and extends to screen 2
This is also Windows 11
Nachricht 15 von 18
Kev_D
Following up with more information.
It happens with all Revit versions. When I create a new project in the same Revit window, while the other project is open, the text goes back to normal on both, but then when I change a view or open my 3D view (even though it is empty) the text jumps back larger.
Nachricht 16 von 18
Have you ruled out Add-ons?  Try disabling Add-ons temporarily.
Help | How to disable add-ons for Revit | Autodesk
Nachricht 17 von 18
Wait a minute. It happens in ALL Versions? Now I'm more convinced that this is a Windows thing.  You're not using Windows 11 by chance?
Nachricht 18 von 18
Kev_D
als Antwort auf: barthbradley
Yes, Windows 11. I also removed the monitors and opened Revit on the laptop screen only, and the problem persists.
