Revit freezes when opening dynamo R23
1 REPLY 1
crapai
141 Views, 1 Reply
Revit is freezing when I try to open dynamo in R23. I've already tried moving all add-in and packages to temp folders to test if there is a conflict. Still freezes. No error message because it never ends. Are there any other steps I should be trying?
Tags (2)
Labels (2)
1 REPLY 1
L.Maas
in reply to: crapai
Can you check your last jounal file to see if something is mentioned in there?
-Look for upgrades to Revit
-Do you have additional packages installed for Dynamo?
-You might also try to to fix .net (look for .NET Framework Repair Tool)
Louis
Please mention Revit version, especially when uploading Revit files.
Forma Design Contest
