Does anyone know why the Lumion plug in is crashing or freezing as soon as I click export button. It does not appear that it is doing anything when clicking the export Lumion button.
Only happens with certain model or with all models even a small one? Are you in a 3d view when exporting?
Have you tried to reinstall the plugin?
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
