Revit Freezes Steel -> Cope
dsmith_scc
dsmith_scc
Hi Everyone,
Having an issue with Revit 2022 freezing with the blue circle when choosing Steel - Cope on a file. The issue is also present with some .rvt files upon trying to open them. I have tried patching Revit to the latest version, updated the video card drivers, turned off hardware acceleration on the video card, etc without success. Any suggestions?
Thanks!
See if Auditing the Files resolves.
...also inspect and resolve possible related Warnings.
...what families are you trying to cope together in the Project? We can test at our end if you want to post the files?
dsmith_scc
Thanks for the reply, I have attempted to audit the files with the same effect...spinning blue wheel and the program freezes.
The freezing with the steel - > cope option causes freezing even with the sample Architecture project included with the program.
When testing my master image with Revit included, Revit seems to function fine until a sysprep is run prior to capturing the image for deployment.
