Is there a revit version for do make shop drawings for curtain wall systems and windows?
Any version.
Also, no programs make drawings for you. You use them to produce drawings. If you need a lot of details for shop drawings then you just have to create a lot of details for shop drawings.
Totally agree with ToanDN.
In addition, Revit has a bunch of functionalities that can improve your work.
1- Over a 2D view in Revit yo can add details, like lines, detail components, imported DWG drawings... Combined with call-out views, you can detail everything. You could have your own library for detailing.
2- In a revit family, yo can add 2D detailing too (symbolic lines, imported 2D Dwg...) and set parameters to control the visualization.
3- A powerful tool are "assemblies". You can select several objects in Revit and create an assembly, then you can obtain independent views of this assembly and lay out in whatever sheet.
4- Also, revit has two kinds of 2D view, that can help: legends and drafting views. Specially drafting views, allows you to make intense 2D detailing.
But if you want to do a 3D detailing, be careful modelling and adding complex profiles and extruding it. A very complex profile extruded, repeated again and again in multiple instances of a family, like a curtain wall mullion or so, can increase a lot the number of vertex of your model, making the operation harder and slower. Not always more is better.
Regards.
