REVIT FLAG FAMILY
3 ANTWORTEN 3
Nachricht 1 von 4
default_unknown
5649 Aufrufe, 3 Antworten
REVIT FLAG FAMILY
Hi anyone here knows how to make a flag pole. I made a family resulting to this (see image below). Just trying to make a simple flag. How to make the image not set into tile appearance. Thank you.
Beschriftungen (1)
3 ANTWORTEN 3
Nachricht 2 von 4
If you do it by By Material Browser ,then it's OK how you did..
  • No tile
  • Adjust the Scale to fit your object
  • Adjust the Offset of the mapped image
    • from my experience , if you work in metric, you have to adjust this offset:
      • turn the Preview >Scene to Canvas to have a visual control of what you do, and change the Offset value so to look OK in this Preview.  For me , it works well if this offset is : X = -Half Scale value and  Y = - Half Scale value
  • Another way , more simple ( if you do not work in Revit LT) is to use a Decal
Constantin Stroescu
Nachricht 3 von 4
syman2000
als Antwort auf: default_unknown
Revit tiling is terrible. It doesn't placed the image from origin point and place it in the middle of the surface. So I would keep it tile and then just change the offset to half of width and height. As a result, you should see flag fill in the entire model.
Nachricht 4 von 4
cjDelaPena8FSSJ
als Antwort auf: syman2000
can i get your rfa flag file if possible?
