In Revit 2023 when I open a Revit file from my computer it automatically opens up a new Revit program. It doesn't open the file as a tab in the program I'm working in. Is there a way to change a setting in order to open the file as a tab? I know I can open it as a tab by opening the file from within the program. In Revit 2022 I used to be able to click on a file in my downloads and it would open the file as a tab.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
I just tried it on my PC, which is pretty much an out of the box install. when I double clicking on a file or dragging and drop the file on the desktop icon, both open Revit with the model as a tab. if I double click a second file it opens a second tab in the current session.
If you double click on another file type, does it open the file or only the program?
Howard Munsell
