Revit file not opening
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
6376 Aufrufe, 3 Antworten
Dear,
Yesterday I was working on two projects in Revit 2018. This morning I could not open the projects anymore. Error after loading 52%: Autodesk Revit is not working anymore.
All other projects, made before yesterday, worked fine.
Is there a solution to fix the files?
3 ANTWORTEN 3
Nachricht 2 von 4
-FDC-
als Antwort auf: Anonymous
Maybe you can post the file so we can check it.
Nachricht 3 von 4
L.Maas
Make sure that you have backups in a safe place.
-Check if one of the backups is still working.
-Try to open the file with audit selected
-Check your journal files and see if and what it is reporting.
-Try to use different computer and see if you can open file there
-If you are on subscription go to your account and create a support ticket and ask Autodesk to have a look.
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 4 von 4
648666
als Antwort auf: L.Maas
Legend!
Helped Thanks!
