revit file crushed
4 ANTWORTEN 4
Nachricht 1 von 5
364 Aufrufe, 4 Antworten
revit file crushed
Hi all, my revit file (Autodesk Revit 2016) kept crushed. See the attachment for details.
And I am for sure my hard drive has enough space. And I use "audit" for the file. And restart my computer. But I still get the same message.
Any help would be really appreciated.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
Thank God for backups Smiley (zwinkernd)
Nachricht 3 von 5
ennujozlagam
@Anonymous hello, try to install latest updates from autodesk and see if helps. if you have 3rd party application try to uninstall. worse scenario clean uninstall and reinstall again your revit program. thanks
Nachricht 4 von 5
als Antwort auf: ennujozlagam
Thanks so much for replying. Do you know where can I find the latest update for Revit ?
Nachricht 5 von 5
ennujozlagam
@Anonymous hello, you can check it HERE and if you under autodesk subscription HERE. thanks
