Hello everyone,
My revit file is not opening. This file is not workset file.
If I am opening file but , Revit take error message.
I attached error Picture.
Can you help me please ?
Gelöst! Gehe zur Lösung
Gelöst von Jacob.westergaard. Gehe zur Lösung
Are you sharing the file over a server? Try to delete all your Local copies.
Also - type in %temp% in the Windows Search box. Delete all your Temp files. Depending on how long it has been since this was done, there could be tens of thousands of files in there.
Hello ,
This file is single model.And I delete temp folder everything.
But I take error message again.
Thanks.
Try to power down and power back up.
Also look at
and
Also - I would resave and rename the newest backup file to see if it works.
I tried this link. But it did not work.
If I opening 0001.rvt and 0006 rvt file did not work. And I take again error message.
Have you restarted your machine?
Which version of Revit?
Can you try to open the file on another machine? This problem could be machine specific.
The links should work - they just did on my machine. That makes me think that your problem may be machine - related.
Yes I restarted the computer.
I am using Revit 2017.
I tried it on many computers.
Can you share your file?
Yikes. Did the same thing to me in 2016 and 2017. Click on the hyperlink at the bottom of the error message and start to create a case.
Tech Support is pretty good about getting back to you - possibly the next day, They may ask for your file. Have you attached your file to your case?
I hope the turn will be fast.
Yes, I've added the file.
Thanks for everything ![]()
Thank you for taking your time to write this in the forum,
There are various reasons for file corruption, it's a general thing with all kinds of files. However, there are some areas that are more common than others, such as:
Throughout the lifespan of Revit 2015 we have 14 updates where each one of them contributes to a functioning product. So if you haven't already, I would check that every single user is running the latest version and this applies to all our products - the Autodesk Desktop App will notify you every time there's a new update - it will be the same for whatever release you may be using.
Note: Updating will not correct already corrupt files.
As to you specific file, if you want I would be more than happy to go through the file and correct whatever might cause conflict.
I will just need you to confirm and I'll send you a link to a folder where you can upload your file.
In any case let me know how you would like to proceed, and if you consider my responds sufficient enough, please mark it as a solution.
Thanks again, have a great weekend,
Hello Jacob,
Thank you for Autodesk.
I'm waiting for you to send me a link.
Greetings
Hey are you please able to help me? The same thing is happening with my file.
I have the same issues and would like to get back at lease some section to the file O can’t loose all of this file at all. I need HELP urgently please and thanks.
