Would like to know the changes made each time by an user in a Revit Model/File. How we can identify the changes in the file, is there any log file/history/ audit trail etc.? to check.
For Ex; If a file is at 60% and moved to 90%, what all are the changes or additions made to the model file can be identified in 90%.if an element/object or family added. is there any way to track with date and time of the relevant user edited, modified and updated. So Basically it would be a audit type for the file content.
Please advise. Many Thanks.
You can check under 'Collaborate, Show History', and then navigate to the latest Central file. It will not show you who did what when, but your users could be encouraged to add comments to these when they sync, which will show.
We use Ideate Explorer to interrogate models, where you can get a total family count (and many other metrics). Check how these change over time. I also check other metrics, such as opening time and sync time against file size. I cannot check what individual users do in the files when there are multiple users.
Thanks for your response and suggestion. Will check the said workarounds.
