A day ago while choosing a folder to save an RFA file to my win 10 PC Revit 2020 which was open at the time gave a fatal error message and closed. Since that time I can only run Revit 2020 if I choose "Run as Administrator". When I choose that option it opens and functions as normal. So not a great problem but one that leavs me wondering what has happened, what a solution might be (reinstall revit?) and if eventually I will also be unable to run it in Administrator mode.
Anyone else had this problem and any suggestions for repairing the problem?
go to your window control panel > user accounts (your login name) > change you account type from standard to administrator and see if helps. this is only apply when you have the rights/privilage to change? and install latest updates from autodesk. thanks
have you try to install latest updates from autodesk and see if helps. if doesn't work then try to change your account type to administrator, do a clean uninstall and reinstall again and see what happen. thanks
