Revit Family
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
269 Aufrufe, 1 Antwort
Revit Family
I would like to assign data that i convert from Inverter to Rfa as wall or floor element.
When i call the project i would like model to be defined to the wall or floor.
Is there  a way to do that? Can you explain how with a video please?
1 ANTWORT 1
Nachricht 2 von 2
Kimtaurus
als Antwort auf: Anonymous
You can't create floor or wall families. These are system families. The only way to model a floor/wall like a family would be using the model-in place tool in the project.
Why do you want to import floor/wall families? There could be an easier method.
Can you post a screenshot of what you're doing?
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
