Revit family with optional window depending on size
panjosTRNAQ
panjosTRNAQ
Hi all,
This is my first post here so hope I'm doing it correctly.
I'm trying to create a door family with the option of having a vision panel if the size is bigger than x.
I don't want to have the vision panel automatically if the size is bigger than x, but rather have the option to have it or not.
Hope that's clear enough and easy enough for someone explain me how to achieve this 🙂
Thanks in advance.
bimscape
You’ll need to use conditional statements to get the sizing correct
And you combine this with a Yes/No parameter to choose whether the vision panel is included even if it meets the size requirements
Kind regards,
Ian
Author of The Complete Beginners' Guide to Autodesk Revit Architecture (free online course)
martijn_pater
See attached. (except value > xxx in your case)
