Revit Family Text
Revit Family Text
sh_shirin
Revit Family Text
sh_shirin
I have a Revit Specialty Equipment family in which I want to write what kind of equipment it is. I have added text to it with Generic Annotation. The problem is when I want to use the view range, when I activate it, I see all the texts that are on the families in the lower levels and I have to hide them one by one. Is there another way? Can I write text in the families?
azad.Nanva
share your view range screenshot ! i think this is because of view range setting.your family work well just the text size is not good one.
sh_shirin
I want to see the site in the plan, but when I define the view range, I have to manually hide the families that have generic annotations.
azad.Nanva
you can use the filter :
(view in My Videos)
sh_shirin
Thank you for your solution.
Isn't there another way to apply these changes directly in the template? If we create a view template, we’ll have to define the filter separately for each level.
azad.Nanva
Yes, that's right. You should have a filter for each floor that wants to look down.
