Revit family (SKP>DWG import) wont show in Revit.
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
ryan9ZSDC
3247 Aufrufe, 4 Antworten
I am having some trouble getting a revit family to show in my revit project. The family is a DWG linked cad take from a sketchup file. It shows clearly in the revit family. I also have placed a reference model line within the family. When i import to my project all i can see is the model line i drew. When i click on reveal hidden elements, i can see it there, but i cannot unhide it.
I have checked Phases, Worksets, Discipline, Visibiliy Graphics, LOD. Nothing seems to show.
Im lost as to why this is happening, especially since i can see it in my model when i click reveal hidden elements.
Any solutions?Annotation 2020-03-27 005124.pngAnnotation 2020-03-27 005322.pngAnnotation 2020-03-27 005351.png
4 ANTWORTEN 4
Nachricht 2 von 5
hmunsell
als Antwort auf: ryan9ZSDC
have you checked your imported categories?
VG Overrides > Imported Categories, make sure everything is checked in Importes in Families
if that's not it, can you post the family?
Howard Munsell
Nachricht 3 von 5
ryan9ZSDC
als Antwort auf: hmunsell
Thank you for your reply,
Everything within the imported categories is turned on.
I have attached the Revit family here for your reference. Any other options?
Thanks.
Nachricht 4 von 5
hmunsell
well it was worth a shot.... :leicht_lächelndes_Gesicht: just an FYI when i bring it into my testing model it comes in just fine. make a New floor plan view (View > Plan Views > Floor Plan) edit type and set the View template to None. does it show in the new view?
Howard Munsell
Nachricht 5 von 5
ryan9ZSDC
Ahhh! I needed to turn on imported categories in the  import settings of VG. Easy. Thank you for your help.
