Revit Family not aligning perpendicular to spline.
5 ANTWORTEN 5
Nachricht 1 von 6
1527 Aufrufe, 5 Antworten
Hi everyone,
I have used Dynamo to generate points from an AutoCAD file, and have joined the points using splines and lines.
I have added line divisions to then grip the cross-section family on. So as you can see, half of the cross-sections are great, but the others won't align correctly.
I need most of the line separate as different portions of the alignment will change in the superstructure.
Any Ideas? I've been trying to follow the REVITalise webinar from the Autodesk University but the methods he has used only consider one line.
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
I would use divided paths to create points along the splines and lines at the interval of your choosing.  Then you can repeat a component (the box) along the paths at every dividing point.
Tags (1)
Nachricht 3 von 6
dzanta
als Antwort auf: ToanDN
Within the family that needs to stay perpendicular, select the adaptive point and go to Instance Properties...verify Orients to is set to Global (z) then Host (xy)
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Nachricht 4 von 6
als Antwort auf: dzanta
Thank you both for replying.
I had already set the divisions the way you have shown in the video for each segment of the line, as well as setting the reference point to that option.
I redid everything and the problem still persists.
Can I attach the files for you to have a more detailed look?
Nachricht 5 von 6
Of course.
Nachricht 6 von 6
mattieb
Did you ever solve this? I'm having same issues & hunting for a solution.
