I have a corner Cabinet that ha a sloped face. I have used sloped reference lines to be tangent to the face. I have a casework window extrusion inside the slope face. I have a glass offset parameter on the edges of the sloped face using reference lines. I can lock the face of the casework window extrusion to the reference lines but when i go to chain the offset there is an error and it removes the lock.
Why?
Is the highlighted offset the one you want to change? Unlocking means the change of your offset parameters is also affecting on the dimensions that you have already locked. It can lead unlocking. Could you try to lock your slope line , not locking the purple vertical line and just locking to the green reference line? I hope it helps you.
the offset that says glazing hinge / latch offset dim is the one not working. lock what to my slope reference line?
