revit family load problem
7 ANTWORTEN 7
Nachricht 1 von 8
477 Aufrufe, 7 Antworten
hi every one
i use revit as mep engineer
and i face problem the items used in system like mechanical,piping ..etc
when i need to use it i require to load this items and i know how to cope this problem but it's require this step
every time .. every project ,, it's so bad waste of time .
i need effective way and solve to this problem please
thanks a lot
7 ANTWORTEN 7
Nachricht 2 von 8
RobDraw
als Antwort auf: Anonymous
Have them pre-loaded into your project template.
Rob
Nachricht 3 von 8
als Antwort auf: RobDraw
ok , now i have the revit family contact like doors, duct, pipes ..etc
and know the path of this
c_program data_ autodesk_ revit 2017_ family templates _ us metric
and make the places inside the revit option correct
and the files i check inside the folder
and load when i make load to it inside the project once i need to use
but >> i require to load every time ,, every time i open project require to load items
Nachricht 4 von 8
Nachricht 5 von 8
RobDraw
Rob
Nachricht 6 von 8
Also make sure you are creating your own template based off of the mechanical template... If you use Default/Architectural you will be hating life.
Nachricht 7 von 8
Corsten.Au
Hi
If you have worked on a project, loading all the families required... then
1. Save that file as a Template " .rte' Revit Template.. and use this template to start a new project.
2. If you have started new project without that template then you can open that template file
and use " Transfer Project Standards " this will allow you to load from other revit file / template..
You need to keep two files open to transfer project standards...You need to keep two files open to transfer project standards...
Corsten
Building Designer
Nachricht 8 von 8
Sujan.Maharjan
You need to learn about setting up a Project Template
"Revit Lies in the tension between what we want to do and what can be done!"
