Revit Family is showing up on floor under in floor plans
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
vanessaH6CHC
297 Aufrufe, 3 Antworten
I have a revit family that I have been working with (attached) for fire rating columns.
The family has a problem where when I place it on the 2nd floor, it is showing up on the main floor plan (screenshot with the family circled in blue. I do not see it hidden or in view in the 3d or in the elevations so I am stumped. It is also not an underlay or view range issue. I have doublechecked. I have also tried to attach the base to the floor, which hasn't helped either.
I have checked that the gypsum is attached to the lower ref level work plane in the family and reloaded it a few times already.
I am new to editing families so any advice is appreciated!
3 ANTWORTEN 3
Nachricht 2 von 4
blank...
als Antwort auf: vanessaH6CHC
In family uncheck "Show Family pre-cut in plan views".
Nachricht 3 von 4
Mike.FORM
The tops and bottoms of the extrusions making the pieces were not locked to the levels in the family so parts of the family were staying associated to level 1.
Here is the fixed family.
Nachricht 4 von 4
vanessaH6CHC
Thank you so much Mike, that fixed it for me.
