Revit Family How can I make an angle?
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
b_guzel
394 Aufrufe, 7 Antworten
Hi everyone this is my first question ı made a family but ı cant made a slope ınstance family types
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: b_guzel
Why don't you make this family a Structural Framing Family, load it into Project and place instances of it however you want?
Nachricht 3 von 8
b_guzel
I tried but I can't open it properly revit always says Can't rotate element into this position.  this is parametric family what ı made ı use this family my roof projects  I was a search autodesk forum then ım found this solutions but ı cant understand how ım work this formula
this is topic adress and message  but ı dont understand
https://forums.autodesk.com/t5/revit-architecture-forum/families-apply-a-slope-parameter-as-a-dimens...
First, I defined a "Roof Slope" instance parameter of type "slope".
Second, I defined another instance parameter called "Slope Angle" of type "angle".
Then, I set the formula for "Slope Angle" to atan(Roof Slope).
I then labeled the appropriate angle dimension with the "Slope Angle" parameter.
Now, I can enter the roof slope as 1/12 and it will automatically calculate the appropriate angle.
Nachricht 4 von 8
You are looking for a solution for a problem that doesn't exist.  That tutorial is not needed for structural framing families.
Use a structural framing family. Place the beam then align it to the roof slope plane in project.
Nachricht 5 von 8
Don't do it that way. You are dumbing down Revit.  Just make that one single component in a Structural Framing Family, load it into Project and use it in Beam Systems.
https://help.autodesk.com/view/RVT/2025/ENU/?guid=GUID-487AE7B8-EBE4-4345-B2C8-016F69AC43A2
Nachricht 6 von 8
Nachricht 7 von 8
b_guzel
thank u recomended first ı changed my family category structural framing but ı have not make a any slope than ım the begining ı draw structural framing family but ı dont make ınstance parameter because my roof object not rectangular
Nachricht 8 von 8
b_guzel
thank u for everything its done ım understand now :leicht_lächelndes_Gesicht:
