Revit Family Editing
3 ANTWORTEN 3
Nachricht 1 von 4
dublinjeffers
179 Aufrufe, 3 Antworten
I am a new user to Revit so I would appreciate your forebearance with my query. This relates to editing of downloadable families, specifically windows. I downloaded a particular window family which appears to have a fixed width and height. When I edit these dimensions to fit my requirements I find that the other components i.e. transoms and mullions don't adjust to fit the new width and height dimensions - is there an easy fix to this? Thanking you for your assistance.
3 ANTWORTEN 3
Nachricht 2 von 4
Simon_Weel
als Antwort auf: dublinjeffers
It highly depends on the Family? There are numerous ways to set up a Family, so.... yeah. Could you upload the family in question?
Nachricht 3 von 4
dublinjeffers
als Antwort auf: Simon_Weel
I have attached the particular window family - you will see that the width and height of this particular window are set and when adjusted the transom and mullion components don't scale with the adjustment.
Nachricht 4 von 4
Tom_Kunsman
The horizontal mullions will never change as they are locked to a specific dimension - if you need those to flex, you would need to make some additional parameters, or some sort of formula -
