Revit Family Array - Start with 1 Module
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
jcrossdesign777
1433 Aufrufe, 6 Antworten
I am working on creating a Revit Family that needs to have a built-in array feature. The model needs to start with only 1 module showing. Then from the properties box, be able to specify whether I want 2 or more of the objects in the array to show. This needs to happen in the x and y directions.
Is this possible? Is there another tool in Revit that will allow me to create a parameter so that it will visually show up like that?
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: jcrossdesign777
Yes. You need 2 elements at the start position. One will array and one will not. Both will have a visibility parameter that will control which one is visible based on whether or not it is arrayed.
Nachricht 3 von 7
jcrossdesign777
als Antwort auf: barthbradley
Wonderful! Could you elaborate on how the visibility parameter would be applied to achieve this?
Nachricht 4 von 7
Well, I also noticed that you want to array is both the x and y directions. This is a lot more complicated and involves nested within nested arrays.
No way I can explain the process.  Take a look at this family and reverse-engineer it.
I don't know what you are trying to array, but a Curtain Wall does basically the same thing: Arrays panels in both the x and y directions.
Nachricht 5 von 7
jcrossdesign777
Thank you! Once I know how to do it one direction, I can figure it out for the other.
Nachricht 6 von 7
What exactly are you creating?  There are several other tools to create array-like objects without fiddling with the actual arrays, formulas, visibility and whatnots.  Most of them are easier to use and more versatile and more flexible.
Nachricht 7 von 7
jcrossdesign777
als Antwort auf: ToanDN
I am creating a ceiling hosted family for a product company - similar to Armstrong products. The decorative ceiling module will be arrayed based on the designer's preferences.
