Gelöst! Gehe zur Lösung
Gelöst von kadmonkee. Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
yes you can. but do remember to backup your families in lower version Revit 2014 in case you may need it in the future. thanks
Hi @Anonymous
I see that you are visiting as a new member. Welcome to the Autodesk Community! ![]()
When you load families into a project, the Revit family library is accessed by default. See HERE for more information.
Once you load a family into a project, it is saved with that project. See HERE to Load and Save Families
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions. Kudos welcome.
Thank you.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
as @ennujozlagam suggested make a backup copy of your families to be upgraded into Revit 2018.
I would open (the backup copies) them in Revit 2018 prior to bringing them into my model , simply to confirm they are still functioning as expected.
you may get varying results when upgrading 4 versions at once.
