Revit Families - Rotational Problem
2 ANTWORTEN 2
Nachricht 1 von 3
axiomcc
199 Aufrufe, 2 Antworten
Revit Family - Rotational Issue
The question is in the image. But I'm essentially trying to create a LOD400 roof panel that can rotate both vertically (for roof pitch) and laterally (for roof direction). I can't for the life of me find anything online that comes close to answering this problem. Anyone have any ideas?
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: axiomcc
In the Family: Check Workplane Based and uncheck Always Vertical
I think I misunderstood. You want a family to flex x, y and z.   3 families nested into each other.
1. 1st family doesn't rotate. Check Workplane Based and uncheck Always Vertical.
2. Nest 1st family into 2nd family and host to Ref. Line Work Plane that rotates in the "z" direction. Associate Parameters from 1st Family to Parameters in 2nd Family. Set up Parameter to control "z" rotation distance. Check Workplane Based and uncheck Always Vertical.
3. Nest 2nd family into 3rd family and host to Ref. Line Work Plane that rotates in the "xy" direction. Associate Parameters from 2nd Family to Parameters in 3rd Family. Set up Parameter to control "xy" rotation distance. Check Workplane Based and uncheck Always Vertical.
Nachricht 3 von 3
