Is it possible to export Revit to a web video format like MP4? Thanks!
Gelöst! Gehe zur Lösung
Gelöst von DarrenP. Gehe zur Lösung
Gelöst von L.Maas. Gehe zur Lösung
Yes, a walkthrough. Is there a plugin available for Revit in order to export to an MP4? I just want to eliminate an extra step of using different software to export to an MP4. If this is not possible then I understand.
what was said above is the recommended way to render out a video
you will have to go through another software to convert to mp4 you will not be able to eliminate this step
DarrenP
