Revit export to iFC including linked DWG
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
Xapod
275 Aufrufe, 1 Antwort
I have a revit model with a detailed toposurface. The model includes a DWG from the surveyor (mostly lines and points, no solid geometery). This information needs to be included in an IFC export together with the toposurface.
I tried to find the right settings in the IFC setup or exploding the DWG or importing the DWG as a family, but I can't seem to get the IFC export including the DWG.
Does anyone have solution for this problem?
1 ANTWORT 1
Nachricht 2 von 2
Yoshiyuki_Miyauchi
als Antwort auf: Xapod
Output to IFC including DWG is difficult with Revit's functionality.
Please click the Accept Solution button if my reply answers your question.
こちらの投稿は役に立ちましたか?良ければ「いいね」お願い致します!
こちらの投稿があなたの問題解決に寄与した場合、「解決策として承認」ボタンのクリックへのご協力をお願い致します。
Yoshiyuki Miyauchi / 宮内よしゆき
openBIM Architect
ONESTRUCTION Inc. Co-Founder & CTO
buildingSMART Japan IFC利用支援小委員会 委員長
bSI BIM Professional Certification | BSI BIM Project Information PRACTITIONER | BSI BIM Asset Information PRACTITIONER
Civil User Group認定インストラクター
y.miyauchi@onestruction.com | TEL:050-3528-8052
Twitter|LinkdIn
