Revit export to dwg - Text inside schedule does not wrap
Lucie.Hanzlikova
Lucie.Hanzlikova
I have been experiencing a problem with exporting Revit sheet to dwg. I am exporting a sheet with a floorplan view and a room schedule. Unfortunatelly the text inside the schedule does not wrap when I open the dwg file. In Revit everything is fine. Any idea where might be a problem?
I also tried to set "Preserve visual fidelity" in export to dwg set up, this works, but I cannot keep this settings as it then messed up my text (in czech language) in the model space.
Thank you
S.Jebakumar
Hi Lucie,
Have you tried Mapping Revit text font and AutoCAD text font .
under Text  font in Dwg u can assign the desired font and save this setting for future use.
Jebakumar
BIM Specialist
