Revit Export to AutoCAD
2 ANTWORTEN 2
Nachricht 1 von 3
467 Aufrufe, 2 Antworten
I am working on a building in Autodesk Revit 2019  & collaborating with a colleague who is working in AutoCAD. I need to export it to AutoCAD. The export is fine, I know how this is done. My issue is when I export a sheet I need it to match the layers & line styles my colleague is using in AutoCAD. He has all the line styles and layers set up. What is the best way to set this up?
Tags (3)
2 ANTWORTEN 2
Nachricht 2 von 3
David_Knight
als Antwort auf: Anonymous
You'll need to spend a bit of time setting that up inside revit's Export setup.
You can read about it here.
essentially you'll have to map everything "This --->  That"
and its a pain.
good luck!
Nachricht 3 von 3
Viveka_CD
Hi @Anonymous
Welcome to the Autodesk community!Smiley (fröhlich)
The links shared by @David_Knight  describes the Modify DWG/DXF Export Setup process. Let me know if this helps resolve your issue and if you seek further assistance.
Also, see the solution by @loboarch on this thread
Please select the Accept as Solution button if posts solve your issue or answer your question. Likes welcome!
