Revit export to autocad
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
mbiAK7WZ
639 Aufrufe, 5 Antworten
Hello
i am exporting some revit files to autocad and i need the elevation height from revit so i kan place elevations points on the drawings in the autocad file but i cant get it to work
i use shared coordinates and all that but cant get it to work
5 ANTWORTEN 5
Nachricht 2 von 6
PrathapSekar
als Antwort auf: mbiAK7WZ
Please furnish more detail to understand the problem you are facing.
Thank You! and please 'Accept As Solution' when you found a solution, to help others.
Nachricht 3 von 6
mbiAK7WZ
als Antwort auf: PrathapSekar
i was a little to fast when i was writing the message my bad, but it should be better now
Nachricht 4 von 6
curtisridenour
Can you share your model? Are you exporting from a 3D view?
Nachricht 5 von 6
Export a 3D view.
Nachricht 6 von 6
mbiAK7WZ
als Antwort auf: curtisridenour
no i didnt use 3d view, but it seems to be working when i do, thanks
