Revit export/save model pack (including attachments/links)
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
wr.marshall
1595 Aufrufe, 5 Antworten
The ability to export/save a model in a location and it would automatically include any attachments/links no matter the format (ie Other Revit models, IFC files, Autocad drawings....). All file paths would automatically be re-pathed to the files in the pack. This whole pack could then be sent to others
Beschriftungen (2)
5 ANTWORTEN 5
Nachricht 2 von 6
@wr.marshall  Have you used eTransmit on the Add-ins tab of Revit?
Kimberly Fuhrman-Jones
Revit Community Manager
Nachricht 3 von 6
Hi, @wr.marshall ,
I thought I commented, but it disappeared. I apologize if this is a duplicate reply. The eTransmit function on the Add-ins tab in Revit will do this for you.
Thank you for your submission!
Kimberly
Nachricht 4 von 6
wr.marshall
als Antwort auf: wr.marshall
I really should investigate what all buttons do. Originally was trained on Revit 8.1. But was in a mechanical field between 2010 and 2019 so was using AutoCAD & Inventor. Second time you have pointed a solution out to me. I will give your proposed solution a try. In the interim I assume your solution will resolve, so move this post to the architectural forum.
On a side note though would it not be easier if there was a save OR export "pack" (eTransmit) option the file menu
Nachricht 5 von 6
@wr.marshall  No worries! The File tab certainly seems to be a logical place for eTransmit. Up until a few years ago eTransmit was a separate add-in to Revit that had to be loaded separately. Probably the reason it still resides on the Add-ins tab.
-Kimberly
Nachricht 6 von 6
wr.marshall
@kimberly_fuhrman-jones that's where it is in AutoCAD & Inventor(on file tab), so some sort of standardisation between products within reason.
