Revit Error on windows 10
I don't know if everyone is also facing the same problem , or if its just me. I happened to update windows to 10 recently and the the quick access toolbar is no longer visible. This was not a problem I had experienced before on windows 8.1. I know its not a gpu error since I updated all my drivers . The funny thing is that it does not display the icons , I can approximate the position of thin lines etc and click on it and it works but then again i misclick sometimes. Its really annoying is there a fix for this ?
dzanta
have you tried resetting your Revit Interface?
rename UIstate.dat to UIstate.old
restart revit
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Just tried that , not wworking
I tried reinstalling revit , that doesnt work either
L.Maas
Follow this article on the knowledge autodesk website. Autodesk is still working on compatibility with Windows 10.
The toolbar good be caused by a .Net library issue.
Louis
Please mention Revit version, especially when uploading Revit files.
When I install Revit 2014 on Windows 10 (32 bit), it says "Unsupported Operating System".
But upgrading Windows 7 with installed revit 2014 to Windows 10, it seems that you can run Revit in Windows 10.
So I think Autodesk have not support the installation of revit on Windows 10 yet.
I haven't tried earlier versions of revit but revit 2016 seems to run fine.
revit 2017 seems to work perfectly
