How can I fix my problem?
I have downloaded Revit 2018 and can open it, but does not allow me to open any sample projects or let me do anything. When I try to, for example, draw a wall this message pops up, "None of the created elements are visible in Floor Plan: Level 1 View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings."
Please Help!!
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Chances are you opening a structural template so that architectural walls will not show when you draw them in a structural plan. Make sure you start from the right template for what you do.
Does the wall you just placed show up in 3D view? Maybe you placed the wall below below the view range (e.g. placed a wall by depth, not height, such as a structural wall.) Check on your options bar when placing wall to see what direction it's going (e.g. "Height" or "Depth"). Or, verify the Base and Top Constraints in the Wall Properties when you place it.
Hi @Anonymous
I see that you are visiting as a new member. Welcome to the Autodesk Community! ![]()
This error occurs when you add an element to a design option, but the element will not be visible in the current view.
Issue: This error may be due to the visibility of elements for the view or design option settings for the view.
Solution: To resolve the issue, try the following:
Click View tab >Graphics panel (Visibility/Graphics). On the Model Categories tab and Annotation Categories tab, check the Visibility settings for the types of elements that you added. If visibility for these elements is turned off, select the Visibility check box to make them visible.
Click View tab > Graphics panel > (Visibility/Graphics). On the Design Options tab, check the settings for each design option set. If they are not set to Automatic or to the active option, change the settings.
Please select the Accept as Solution button if my post solves your issue or answers your question. Likes welcome!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
@Anonymous Did you look at this article and try the recommendations?
Viveka CD
I didn't read this before. Something else may be going on here. Try doing a Repair.
Hi @Anonymous
I just wanted to follow up here, any progress on this issue?
Did you have a chance to look at the previous posts?
I look forward to hearing from you!
Viveka CD
Chances are you opening a structural template so that architectural walls will not show when you draw them in a structural plan. - So Just select the plan view on the project browser and open the properties palette. Under the Identity data there is a view template and Just change it to Architectural plan.
click on modify , than on property browser , scroll down and click on view range (than edit). on the depth tab change associated level (top foundation ) to level below ( bottom foundation)
Hi guys. My name is Willians and I'm new here.
I already had the same problem before.
I solve it this way: change the discipline to architectural, maybe it's structural.
