Please see attachment. Remove from startup of Revit. Ver2017.
This isn't a Revit error, it is the PDF Maker you are using that is using an unsigned driver.
To get past this, go to the file in question and right click and select properties. Go to the Security Tab and there should be a Security button (or similar) that will allow the driver to run.
See this article https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Autodesk-Revit-reports-e...
