revit entourage familes
5 ANTWORTEN 5
Nachricht 1 von 6
2672 Aufrufe, 5 Antworten
Respected sir /Madam,
                        i saw a lot of websites and you tube also but not found .please will we posted   the   entourage type families video in youtube or any revit community website .  entourage family means cars ,trees, humans ,some type of rcp families etc.
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
Nachricht 3 von 6
Corsten.Au
Extract from apps.autodesk.com
Hope this will help you.
FREE ArchVision RPC Entourage Starter Pack
Win32 and 64, English
2018 now supported! Download and Drag & Drop RPC Content into Autodesk® AutoCAD®, Autodesk® Revit® & Autodesk® 3ds Max®. Place, edit & render thousands of RPC People, Trees, Cars & Objects.
https://apps.autodesk.com/RVT/en/Detail/HelpDoc?appId=4500868201744478807&appLang=en&os=Win32_64
http://labs.archvision.com/
https://www.youtube.com/watch?v=Eae3pcl4028
Cheers!
Corsten
Building Designer
Nachricht 4 von 6
als Antwort auf: Corsten.Au
Hello ganesh,
I've been looking for new entourage families and how to create them, which is why I'm here.  I still cannot make this work.  Do you have any videos or info. as to how to make entourage in Revit, I cannot.  I thought this would be as easy as it says but I cannot figure it out....
JLeibold
Nachricht 5 von 6
Sahay_R
In elevation views - I would prefer to use Detail Components for entourage.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 6 von 6
constantin.stroescu
you can make your own Entourage Family if you have a 3d dwg model and blueprints of an object.
That could be the case of cars. You can easy find .dwg blueprints of different car types. You can import these blueprints separately ( top, side , front and back) into your Entourage Family and control the visibility so to appear only in selected views . There will be no 3d , only a bunch of 2 d views that will appear on the same position in plan , elevations and section views. But if you find a 3 d model , you can import it to and place in the same position and make it visible only for 3 d views...
Constantin Stroescu
